Side menu
Thread begun 11/14/2011 3:50 am by john70964 | Last modified 11/14/2011 10:44 am by john70964 | 5381 views | 6 replies |
john70964
Side menu
When I look at the Home Page I have one menu across the top.
However when I open the Products page I have the menu at the top and down the left side.
I don't need two menus showing the same thing.
Can I remove either of these menus?
John
you could remove the menu from the top by editing the webassist/plugins/main_menu/menu.php file.
remove the following code:
<?php if ($totalRows_menuwriter_categories > 0) { // Show if recordset not empty ?>
    <?php do { ?>
        <li class="parent"><a href="../../../products_results.php?Search=1&ProductCategoryID[]=<?php echo $row_menuwriter_categories["CategoryID"]; ?>"><?php echo $row_menuwriter_categories["CategoryName"]; ?></a>
          <?php echo(recursiveNesting($row_menuwriter_categories["CategoryID"])) ?>
        </li>
<?php } while ($row_menuwriter_categories = mysql_fetch_assoc($menuwriter_categories)); ?>
} // Show if recordset not empty ?>
john70964
Thanks Jason
Could I remove the side menu?
yes, it's possible, but that is not supported. it would require deleting the div that contains the side menu and editing the CSS AS well. it is a much bigger modification.
if you want to go down that route, i would suggest signing up for a premiere ticket appointment where we would work with you in a one on one scenario.
john70964
Thanks Jason
If I remove the menu from the top of all pages, what happens on the home page as that only has the top menu.
the top menu on the home page will not have links to the categories.
john70964
Thanks Jason
Getting the idea!
