Change menu spacing
I would like to reduce the depth/height of menu items.
How can I do this please?
John
John
this can be done by editing the css for the menu.
Using FireFox and fire bug, you can inspect specific elements of your page and see the css controlling them to drill down to the edits that would need to be made, and which files to make the changes in.
if you need further assistance, send a link to your site.
in the webassist/themes/FB1/css/default_styles.css you will need to edit the #cssmw a and #cssmw li:hover > ul a selectors.
its a matter of adding a height attribute, and adjusting the padding top and padding bottom attributes. keep in mind that the tru height of an element is height + padding top + padding Bottom
then you will need to add a margin bottom attribute as well.
