Image Resizer in an href
Thread begun 11/13/2011 12:19 pm by Brainthief | Last modified 12/06/2011 7:41 am by Jason Byrnes | 5299 views | 8 replies |
Brainthief
I am trying to use image resize with another script. The script reveals a larger image inside of a div using an href...
Does anyone know... what is the best way to insert a dynamic cached image in an href like below?
Thanks!
if(TRUE){ // Begin Cached Resized Image: ImageCacheInstance_1321208809944
ob_start();
<a href="PATH TO LARGE CACHED IMAGE HERE" rel="enlargeimage" rev="targetdiv:loadarea,link:http://somewhere.com"><img src="images/<?php echo $row_rsImages['filename']; ?>" alt="" name="" width="32" height="32" /></a>
echo(getCachedResizedImageHTML(ob_get_clean(), "image_cache", "crop", "", false));
} // End Cached Resized Image: ImageCacheInstance_1321208809944
Dani Chankhour
What you will need to do is find the location of where the image is being stored by image resizer. Then you will need to use that url in the href="" and switch the image file name to by dynamic (pull it from the record set).
Brainthief
Thanks for the reply...
I have used the path to the full size image but that is not what I want...
<a href="gallery_images/<?php echo $row_rsImages['filename']; ?>" rel="enlargeimage" rev="targetdiv:loadarea,link:http://somewhere.com">
I want a thumbnail image...
How do I specify a path to generate a new dynamic image?
Brainthief
Can you show me an example?
Dani Chankhour
You need to use the path that is generated by image resizer.
Can you please send me a url of where i can see an image resized by image resizer and i can explain how to modify the href.
Brainthief
Please give me an example of a path that is generated by image resizer?
The large image is not created. there is not a path to it. I need to create it from the thumbnail code below.
This is how I'm creating the thumbnail;
ob_start();
basically, you need to create a page that will use image resizer to create the large images. Open that page in a browser and view the source code.
the source code will show you the path to use to access them in the anchor tag.
Brainthief
I still have not got this to work.
Thanks for your help.
I created a page and this is the code used from image resizer;
if(TRUE){ // Begin Cached Resized Image: ImageCacheInstance_1323139609713
ob_start();
<img src="images/<?php echo $row_rsImages['filename']; ?>" width="300" alt="test" />
echo(getCachedResizedImageHTML(ob_get_clean(), "image_cache", "proportion", "", true));
} // End Cached Resized Image: ImageCacheInstance_1323139609713
And this is the generated path;
<img src="image_cache/images/proportion/adr20_w300_h482/adr20_11290527.jpg" width="300" alt="test" />
I need for the image to be dynamic.
I can't hard code to the larger image...
The original image name in the database is adr20.jpg and the original size is 600px wide.
There could be 1,000 images at any time, the width should be resized to 300px wide, the height will be determined by the original uploaded image, old images get deleted and new ones get created often.
When the user hovers over the small image it should reveal the larger, 300px wide, image in the div "loadarea"...
How do I make "image_cache/gallery_images/proportion/adr20_w300_h482/adr20_11290527.jpg" dynamic?
The small image works just like I want it...
Here is the small image and the link;
ob_start();
<a href="PATH TO LARGE 300PX WIDE CACHED IMAGE HERE" rel="enlargeimage" rev="targetdiv:loadarea,link:http://somewhere.com"><img src="images/<?php echo $row_rsImages['filename']; ?>" alt="" name="" width="32" height="32" /></a>
How do I get the below into the href?
ob_start();
Image resizer cannot dynamically generate the path used in the href tag. This is a limitation of image resizer.
it can only resize the images, it cannot dynamically generate the path used by the href tag.
