interested in SA2 some advice needed
Thread begun 11/11/2011 3:33 pm by mr hankey | Last modified 11/24/2011 12:09 pm by mr hankey | 2624 views | 4 replies |
mr hankey
hi,
not been on here for a while and looking at buying some extensions again, one of which is the SA2.
i have been reading around and i need to know which is the best password encryption to use? is Crypt the best? i.e. can it not be reveresed?
i used sha1 one with sa1 and currently have sites running using md5.
question is does it matter which one as people cannot reverse it unless they have access to the raw mysql database on server is that right? or should i use crypt with sa2?
also what measures should i take to stop people gaining access to the server, do you guys have any help guides on how to keep things secure with your backend database?
and findally does sa2 have an automatic detection of brute force and failed login attempts triggers the user to be inactive for a set period?
i liked this feature with addt and wondered if sa2 had this?
thanks for the help
SHA1 and Crypt are both one way encryption methods, meaning they cannot be decrypted, both are good choices for encrypting passwords.
md5 is two way encryption method meaning it can be both encrypted and decrypted.
stoping people from gaining access to the zerver falls under server configuration, setting up strong usernames and passwords for MySQL access and for FTP access. we do not have tutorials for configuring the server, this should be handled by your host.
No, security assist does not any built in protection from brute force login attempts.
mr hankey
thanks jason, so is there no way for it to recognize failed login attempts?
thanks
anonymous
hankey,
You could quickly write your own script for that because when you set up security assist, you get to set the login failed page.
So let's say your login page is "login.php".
And then in the SecurityAssist dialog for failed login, you specify the redirect as "login.php". You could add the a URL variable to the redirect such as "login.php?fail=1".
Now back on your login page, you would add code like this:
First, be sure you have a session start at the top of the page.
<?php session_start(); ?>
Then below that somewhere, you will need to create a session variable and then increment that variable on each failed attempt. Then you can test that variable for failed attempts and create an action.
// This will check to see if the session variable for failed attempts has been set and if not set, it will set it
if (!isset($_SESSION['failedAttempts'])) {
       $_SESSION['failedAttempts'] = 0;
// This will store the session variable into a variable name easier to work with.
$failedAttempts = $_SESSION['failedAttempts'];
// This code will check for the URL variable to passed after a failed login and then add an increment operator to the failed attempt variable
if (isset($_GET['failed']) && $_GET['failed'] == 1) {
      $failedAttempts++;
// this statement will see if the failed attempts is higher than 5, if so, it will redirect the user to another page which will keep them from accessing the login page
if ($failedAttempts > 5) {
      header("Location: nologin.php");
       exit();
You could get even fancier and add a session time out, but the default of 30 minutes should be good so I would probably just leave it alone.
Of course, you will want all of this code before the WebAssist login code.
Best regards,
Brian
mr hankey
thanks for the help i like the code will definately look into this.
cheers
