Image Resizer folder permissions
Thread begun 11/11/2011 1:50 am by mail393820 | Last modified 5/28/2012 5:37 am by mail393820 | 8249 views | 18 replies |
mail393820
Image resizer seems to be creating the thumbnails on the server as expected but they aren't displaying on the page. When I navigate to the folder ie. "image_cache/assests/images/pix/crop/wed-pic-05_w90_h90/wed-pic-05_11101223.jpg" to view the image I get the following message in my browser "Forbidden - You don't have permission to access /image_cache/assests/images/pix/crop/wed-pic-05_w90_h90/wed-pic-05_11101223.jpg on this server." I would be grateful for your help and advice on how to rectify this.
using an ftp program like FileZilla:
filezilla-project.org/
browse to the /image_cache/assests/images/pix/crop/wed-pic-05_w90_h90/wed-pic-05_11101223.jpg file on the server, right click and select File Permisions. Try chnaging the permissions level to 755 the try viewing the file again in a browser.
if that works, use File Zilla to change the permissions for the /image_cache/ folder, and set it to Recurse through all files and folders under it.
Then in dreamweaver, edit the webassist/caching/CachedResize_Image.php file
change line 229:
mkdir ($cachefolder,0777,true);
mkdir ($cachefolder,0755,true);
mail393820
Thanks Jason. At first your advice seemed to work but when a new thumbnail was created the permissions for new folders were different again so the thumbs that were already on the server display ok but the newly created ones show only as a question mark. Can you suggest anything else to try? I appreciate your help.
Dave BuchholzBeta Tester
I have encountered this issue as well so I would be interested in the solution.
info269075
Same problem
Hello because of this problem i never could use the extension, so if there is a solution now, I will take it.
Dani Chankhour
Can you check to make sure the folder that is storing the images have read/write permissions?
If that is still an issue, can you tell me if you are getting the same error listed above or a different error.
Thanks.
mail393820
Each time image resizer creates a new folder on the server the folder is set with the wrong read/write permissions. I have to manually change permissions for each new folder before the image will display on the webpage. I am desperate to get this working so any help is greatly appreciated. Is there any way around this? Would it help if I could choose the thumbnails to be saved to a master thumbnails folder rather than a unique folder for each image?
try changing line 6L
return is_dir($pathname) || @mkdir($pathname);
    chmod($pathname, 0777);
