Live Server Warning: Cannot modify header information
Thread begun 11/10/2011 7:31 am by Steve E | Last modified 11/10/2011 9:19 am by Steve E | 2636 views | 4 replies |
Steve E
Hi
I have 4 admin pages that seem to effected by errors on my live server,
Edited for security
The Pages worked fine on my local machine but in on my live server I have a problem. I assume it is something to do with the amount of times session occurs in the script but I do not want to mess it up as it seems to function, I just get the errors displaying.
If you could have a look and see why this is I would be grateful, I have tried moving various require once field around but can not identify exactly what I need to move in order to get this to work
Thanks in advance
see this thread for details on the headers already sent error:
showthread.php?t=19285
according to the error messages, the problem is happening around line 11 of the events_Update.php page:
output started at /home/ffstylec/public_html/Administration/events_Update.php:11
line 9 of the events_Update.php page has a blank space at the end of the closing php block, this space is causing the error, and needs to be deleted
and around line 42 of the events_Detail.php page:
output started at /home/ffstylec/public_html/Administration/events_Detail.php:42
line 41 of the events_Detail.php page has a blank space at the end of the closing php block, this space is causing the error, and needs to be deleted.
Steve E
Jason you are a diamond thank you very much, all these pages were suffering from whitespace, I will look out from that in future, just for my information, why does this not happen on my local server?
Thanks again and all the best
it has to do with the error reporting level.
you local server has the error reporting level set to ignore warnings, but the live server is set to show warnings.
Steve E
Ok thanks very much
