css form builder & tooltips
Thread begun 11/09/2011 3:56 am by ijs174940 | Last modified 11/10/2011 12:06 pm by Jason Byrnes | 3918 views | 3 replies |
ijs174940Beta Tester
This extension works fine for most of the forms I create in css form builder but whenever I have more than two elements in a set that have spry validation this extension does not change the warnings format. There is no problem if there is only one in the set, see the images I have attached to explain more.
the spry error message is attached to the set. select a set, and you will have the option to set the error message to show for that set.
if you want to show individual errors for each element, they must be in individual sets.
Hi Jason
Er... that is not the answer to the question. The error text is correctly placed in the set as can be seen from the attachment the issue is spry tooltip error is not formatted correctly as can be seen from the second image from my previous post.
Sorry, i misunderstood the issue, can you send a link where i can see the problem, or a copy of your page in a zip archive.
