Image Enlarging with UE4.1
Thread begun 11/08/2011 6:16 pm by doug.lemesurier305760 | Last modified 11/09/2011 11:01 am by doug.lemesurier305760 | 1311 views | 2 replies |
Is it possible to enlarge an image when uploading with UE4.1?
I know UE4.1 will reduce a large image to a specified width, height or both when using the Upload Files server behavior.
What I would like to do is re-size a smaller image to a larger, uniform size when using the Upload Files Server behavior. I know the image may look 'kind'a messed up' but it's what I need.
Any input is appreciated.
Cheers
Doug
No, Universal Email cannot enlarge the image, but you can do this by adding height and width attributes to the image tag, if you specify a larger height and width, the image will be stretched:
<img src="path/to/image.jpg height="300' width="300" />
Thanks Jason,
I need to find a dynamic solution. I know it's not something you would normally want and I can understand why UE would not enlarge.
My problem is that the SOME of the client's images are to small for the jquery zoom I am using. They need to be able to see some details on the images they upload. I've let them know that enlarging a small image will not help but they say it's better than nothing.
So, I like to keep the client happy.
Back to the drawing board.
Cheers!
Doug
