Password Recovery
Thread begun 11/07/2011 6:43 am by goat200487425014 | Last modified 11/09/2011 10:28 am by Jason Byrnes | 4391 views | 11 replies |
goat200487425014
Password Recovery
I am trying to figure out how to setup the password recovery option. I already ran the wizard to generate the page. Are there tutorials for this? I seen the one tutorial in the archive documentation, but I didn't know how relevant it is now.....
I dont follow what you mean, the wizard should have created the forgot password page for you.
is the page the wizard created not working? if so, send a copy of the page the wizard created and description of the issue.
goat200487425014
The wizard did create it. What I am asking is how do I set it up to actually send the password to users email? Aren't there some settings I need to add like email server etc....
I see, in the server behaviors panel, double click the Email Password server behavior, in the email password server behavior, you will need to set the SMTP Server and port that should be used to send the email.
If you are not sure what to enter here, contact your host.
goat200487425014
Will I be able to test this locally?
no, not unless you have an SMTP Server installed.
goat200487425014
Can you tell me how to fix the text fields from showing in the browser?
goat200487425014
Also, The email password server behavior you were talking about editing, is it SecurityAssist Encrypted Password server behavior?
you have another issue I started a ticket for, I will look into this issue at the same time.
goat200487425014
Ok, I have updated ticket !!
