product insert/update pages
Thread begun 11/07/2011 6:29 am by goat200487425014 | Last modified 12/02/2011 2:52 pm by goat200487425014 | 8985 views | 32 replies |
goat200487425014
I followed the tutorial you pointed me to for adding the size options for each product on the insert/update pages but all of my options are showing the same size? How do I get them to show the correct sizes and populate the right fields?
the manage relational table behavior is not applied to the update page you sent, so i cant speak to that one, but on the insert page, you set the repeat region for the options check box to use the WADADynListproductcategories recordset, it should be using the rsoptions recordset instead.
goat200487425014
Ok I have corrected that part, but I still get this error at the top of my insert page:
Notice: Undefined variable: _SESSION in C:\xampp\htdocs\LuckiexLosers\admin\products_Insert.php on line 148
dont worry about that. it is not an error message, it is only a Notice and is only showing because you have the php error level set to show notices, warnings and errors.
the page should still function correctly and the notice should not show on the live server where the reporting level does not include notices.
goat200487425014
Well it is still showing the same size option for all of them
code for the manage relational behavior will be generated based on the repeat region used at the time it is applied.
you will likely need to revert the page to the point before you added the manage relational table behavior, then correct the recordset used by the repeat region, then reaply the manage relational table behavior.
goat200487425014
I have redid both of the pages. but when I try to insert a new product I get this error:
Unknown column 'CategoryName' in 'field list'
I tried going back to add the same SQL statements that you told me to add the other pages but that didn't work either.
goat200487425014
Ticket updated!
goat200487425014
Will someone be calling me today regarding this ticket??
