Honeypot Spam Prevention - WA Server Validations
Thread begun 11/05/2011 9:32 am by dlovas275157 | Last modified 5/11/2018 5:35 pm by Ray Borduin | 6284 views | 12 replies |
dlovas275157
I am trying to add a honeypot to my form to help prevent bot spammers from filling out my forms.
I have a textfield that is positioned off the page with css
position: absolute; left: -9000px
The textfield by default is empty. If a bot enters anything into the field, I want it to fail. How to do I set up this validation? can't seem to find an option in the Server Validation Dialog that requires the field to be empty.
Help is appreciated.
use regular expression validation. set the Allow Blank entry option and use the following regular expression:
/^$/i
dlovas275157
Jason,
Great...that worked!
What does "/^$/i " mean, and why does that work?
the leading / denotes the start of the expression
^ anchors the regular expression to the start of the line.
$ anchors it to the end of the line.
/i means case insensitive
The regular expression basically says:
Do a case insensitive search for the start of a line being right next to the end of a line
in other words, blank entry.
if you want more info on regular expressions, see the cheat sheet here:
regular-expressions-cheat-sheet/
JBWebWorks
I use this regular expression for honeypot spam prevention and has worked fine until the last few months. For some reason I am now getting bot spam.
if (isset($_POST["submit1"]) || isset($_POST["submit1_x"])) {
$WAFV_Redirect = "";
$_SESSION['WAVT_index_202_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateRQ(((isset($_POST["player1"]))?$_POST["player1"]:"") . "",false,1);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["tee1"]))?$_POST["tee1"]:"") . "",true,2);
$WAFV_Errors .= WAValidateRX(((isset($_POST["addblock"]))?$_POST["addblock"]:"") . "","/^$/i",false,6);
$WAFV_Errors .= WAValidateRX(((isset($_POST["seconddblock"]))?$_POST["seconddblock"]:"") . "","/^$/i",false,7);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"index_202");
<div id="form1_ProgressWrapper">
<span style="display:">
<?php $selected = explode(", ", ValidatedField("index_202","player1")); ?>
</span>
<form action="" method="post" enctype="multipart/form-data" name="form1" id="form1">
<input name="addblock" type="text" id="addblock" style="display:none" value="" />
<input name="seconddblock" id="seconddblock" type="text" style="display:none" value="" />
<label for="player1"><strong>*Your Name:</strong></label>
<select name="player1[]" id="player1" onchange="setSatsignup(document.form1.player1[document.form1.player1.selectedIndex].value)">
<option value="" selected="selected">Select From Dropdown</option>
do {
<option value="<?php echo $row_rs_members['FirstName']?>,<?php echo $row_rs_members['LastName']?>,<?php echo $row_rs_members['GHIN_Number']; ?>"><?php echo $row_rs_members['FirstName']?> <?php echo $row_rs_members['LastName']?></option>
} while ($row_rs_members = mysql_fetch_assoc($rs_members));
$rows = mysql_num_rows($rs_members);
if($rows > 0) {
mysql_data_seek($rs_members, 0);
$row_rs_members = mysql_fetch_assoc($rs_members);
</select>
if (ValidatedField('index_202','index_202')) {
if ((strpos((",".ValidatedField("index_202","index_202").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
<span class="stylered">Name required</span>
<?php //WAFV_Conditional index.php index_202(1:)
<br />
if (ValidatedField('index_276','index_276')) {
if ((strpos((",".ValidatedField("index_276","index_276").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
<span class="stylered">You are already signed up for Saturday</span>
<?php //WAFV_Conditional index.php index_276(3:)
<br />
<label for="email1"><strong>Email Confirmation </strong></label>
<select name="email1" id="email1">
<option value="" <?php if (!(strcmp("", (ValidatedField("index_202","email1"))))) {echo "selected=\"selected\"";} ?>>Select your Name if you want an email confirmation</option>
do {
<option value="<?php echo $row_rs_members['EmailAddress']?>"<?php if (!(strcmp($row_rs_members['EmailAddress'], (ValidatedField("index_202","email1"))))) {echo "selected=\"selected\"";} ?>><?php echo $row_rs_members['FirstName']; ?> <?php echo $row_rs_members['LastName']?> </option>
if($rows > 0) {
</select>
<br />
<br />
<label for="tee1"><strong>*Your Tee Choice:</strong></label>
<select name="tee1" id="tee1">
<option value="" selected="selected" <?php if (!(strcmp("", (ValidatedField("index_202","tee1"))))) {echo "selected=\"selected\"";} ?>>Select Your Tee</option>
<option value="Gold" <?php if (!(strcmp("Gold", (ValidatedField("index_202","tee1"))))) {echo "selected=\"selected\"";} ?>>Gold</option>
<option value="White" <?php if (!(strcmp("White", (ValidatedField("index_202","tee1"))))) {echo "selected=\"selected\"";} ?>>White</option>
<option value="Blue" <?php if (!(strcmp("Blue", (ValidatedField("index_202","tee1"))))) {echo "selected=\"selected\"";} ?>>Blue</option>
</select>
if ((strpos((",".ValidatedField("index_202","index_202").","), "," . "2" . ",") !== false || "2" == "")) {
if (!(false)) {
<span class="stylered">Tee Required</span>
<?php //WAFV_Conditional index.php index_202(2:)
<br />
<br />
<label for="pairing1"><strong>Notes or Message:</strong></label><br />
<textarea name="pairing1" id="pairing1" cols="45" rows="5"><?php echo(ValidatedField("index_202","pairing1")) ?></textarea>
<br />
<br /><input name="FirstName" id="FirstName" type="hidden" value="" /><input name="LastName" id="LastName" type="hidden" value="" /><input name="GHIN_number" id="GHIN_number" type="hidden" value="" />
<input type="submit" name="submit1" id="submit1" value="Submit Saturday Signup" />
</span>
</form>
</div>
It must be smart enough to avoid your honeypot. I'd maybe try adding CAPTCHA or a simple question validation.
JBWebWorks
Ray,
is there a way to use regular expression in validation toolkit to block the words url, http, or https from a textarea. That seems to be what the bots put in my form.
Yes you can use a regular expression for that. I did a google search for "regular expression exclude word" and got:
^/(?!ignoreme|ignoreme2|ignoremeN)([a-z0-9]+)$
JBWebWorks
This post has been deleted.
JBWebWorks
Thanks Ray.
I used regular expression with these words ^/(?!url|http|https)([a-z0-9]+)$
It won't allow any word?
