SecurityAssist lose the session and returns to the login screen
Thread begun 11/02/2011 10:03 pm by Vinicios Nussemeyer | Last modified 11/03/2011 5:14 pm by Vinicios Nussemeyer | 3196 views | 4 replies |
Vinicios Nussemeyer
Hello
The Admin area of my site has several pages protected by privilege level. I created the rule SuperAdmin and was working perfectly. But it was not until I upload 4 new pages with the same access rule that my problems began. I login, browse a few pages and suddenly he goes back to the login screen. It seems that the pages lose SecurityAssist_UserID session. It seems that the user is not logged into the system. I've applied in the first line this code I got here in the forum the same <?php @session_start(); if(isset($_SESSION['SecurityAssist_UserID']) && $_SESSION['SecurityAssist_UserID'] != "") $_GET['loggedIn'] = "1"; ?>....
It works a bit and back to the login screen again.
What can this be?
Vinicios Nussemeyer
Hello Jason.
I solved the problem. I uploaded a file that did not include protection for login. Applied protection and is apparently resolved.
Now a warning appears every time I try to update a data file. The message is the standard that I can not change the Header. But the strange thing is that this file was created by DataAssist the same way as others and this only gives the message. I can upgrade but it does not direct to Result Page. If I give a refresh on the page appears the changes.
Follows the line that appears with the warning and also a JPG with the line that references the 108 error.
Warning: Cannot modify header information - headers already sent by (output started at /home/portalcpos/webapps/ROOT/admin/inscr_eventos_Update.php:5) in /home/portalcpos/webapps/ROOT/admin/inscr_eventos_Update.php on line 108
Thank you.
the problem is cause by blank space around line 5:
see the following thread for details:
showthread.php?t=19285
Vinicios Nussemeyer
Ok Jason.
Tanks
