Inserting Blank Record
Thread begun 11/02/2011 10:31 am by doug.lemesurier305760 | Last modified 11/03/2011 11:00 am by doug.lemesurier305760 | 2390 views | 4 replies |
I can't seem to figure out why this form is only inserting a blank record. The form returns no errors and does not insert the form values but it inserts a empty record into the db. I just can't find where it's gone wrong.
to troubleshoot, change this line:
$MM_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
echo("<pre>".var_dump($_POST)."</pre><br>");
die("SQL: ".$WA_Sql);
this will write the contents of the post and the Insert SQL Statement to the screen, post this information back.
Thanks Jason,
The result indicates that nothing is being inserted into the values.
array(9) { ["Registration_group_Company_Name"]=> string(12) "Temp Company" ["Registration_group_Company_Abbrev"]=> string(5) "tcomp" ["Registration_group_Email"]=> string(16) "temp@company.com" ["Registration_group_Address"]=> string(3) "999" ["Registration_group_Address_2"]=> string(0) "" ["Registration_group_City"]=> string(4) "9999" ["Registration_group_Province"]=> string(7) "Alberta" ["Registration_group_Postal_Code"]=> string(7) "L6V 4L2" ["Registration_submit"]=> string(11) "Add Company" }
SQL: INSERT INTO `companies` (`CompanyName`,`CompanyAbbrev`,`CompanyAddress1`,`CompanyAddress2`,`CompanyCity`,`CompanyZip`,`CompanyEmail`,`CompanyState`,`CompanyCountry`) VALUES ('','','','','','','','','')
But the field names are correct. I can not see why the field values are not being passed
Turns out, I neglected to upload all of the necessary WA files that were to be included with the page for validation.
