File Upload
Thread begun 11/01/2011 5:14 pm by msbannister373603 | Last modified 1/26/2012 12:35 pm by Jason Byrnes | 4746 views | 10 replies |
msbannister373603
File Upload
I've searched the message board for detailed on instructions on using the file upload feature of universal email. This extension seems to be complicated. I can't figure out how to get the file to upload and the name to store in the database. None of your solution recipes give instructions on these issues. After I apply the behavior to the file field how do I use the bindings in the and which bindings do I apply. I know I'm probably missing something simple. Are they any detailed instructions available?
msbannister373603
Figured it out
I finally figured this out if anyone is interested. After looking at the code for the upload for hours, I figured out when I changed the overwrite command to Rename existing file the extension finally worked. When you choose the overwrite command it places a 0 in the code where you choose which file to upload. When you use any option besides overwrite it chooses the 2, 3, 4 options and it works nicely.
Magega49
Uploading Files to my server
Hello,
Can Any one help please?
I want to know how to set up a form in dreamweaver, to let user upload images to my server please???
create a new php document in Dreamweaver.
Go to Insert -> Form -> Form to create the form.
Go to Insert -> Form -> File Filed to add a file field to the form.
go to Insert -> Form -> Button to add a submit button to the form.
Now go to Insert -> WebAssist -> File Manipulation -> Upload file to add the file upload server behavior.
in the upload server behavior click the help button for more details on tjhe various settings.
Magega49
Work Great!!!
Thank you it workout Great,
But I just want to know if I can add another field to ask user for their order number??
How do i do that? Please...
yes, you can add another field, the same way you added the submit button and the file field, go to Insert -> FOrms and select the appropriate element type (Probably a text box in this case).
Magega49
Thank you so, much!!!!
Thank you....
So, much!!!!
Magega49
File Upload
Sorry guys,
But i m receiving the files but I don know how to set it to get text information on my personal email....
I want user to upload the files and to be aivle to enter a order number and user email address...... The files upload fine is just the user informaion that I need help with..
Please!
you need to add the universal email Create email message behavior, Insert -> WebAssist -> Create Email Message.
select the option to Create a file for the email to have the form information automatically sent to you.
make sure to supply a valid from and to email address in the settings.
Magega49
Thank you, So, Much!!!!
Another question I want to know how can I set the form to create a folder for each user or to tell me the user order number relate to the file being upload...
For sample:
if you purchase a business cards to be print in my site, I will ask you to upload your artwork after you finish the payment...
How I will know that this artwork is coming from that person that just order...
Can the order number be add automatic to the message form, field??? Or can I have the system created a folder for each user that will upload files in there????
This is very important for my web site in order to work properly to better servce my client on line... Please help me on this if you can (-:
