Red Exclamation Mark next to eCart object
Thread begun 10/29/2011 1:33 am by steve287725 | Last modified 11/11/2011 10:26 am by Jason Byrnes | 4967 views | 9 replies |
steve287725
I have a red exclamation mark next to the eCart Object in the Server Behaviors panel - just on some pages.
All however appears to work OK - is there any way I can find out what this means?
I have done all the usual like deleting the cache etc.
the red exclamation mark only means that there is code on the page that Dreamweaver is not inspecting correctly. It means there is a _possibility_ that there may be a problem on the page and you should test it in the browser.
if it is working in the browser, you can ignore the red exclamation mark, if it is not, then the exclamation mark may help[ you find the culprit.
steve287725
Thanks but more errors . . .
Thanks for that - I thought that the reply may lead me to an answer to a problem which has appeared in the forum before but appears not to have a resolution.
I am having EXACTLY the same issue but with DW5 instead of DW4
showthread.php?t=3939&highlight=executing+OnLoad+WADA+Repeat+Selection.htm%2C+Javascript+error%28s%29+occurred
Do you have any record of this being resolved please?
I have a combo box on the same page - if I add a straight DW repeat region to the table row then that appears to work OK, but the data then disappears out of the combo box - this may help diagnosis?
Both repeat regions apply to the same recordset.
I have attached the behaviors panel as requested in the previous post by the other guy
Thanks and regards
Steve
steve287725
Same Site - Checkout Button
Jason
Thanks for your help the other evening - I am at the last stage of a complex shop - I have just run the Checkout wizard which has produced the pages fine but the Checkout button on the cart page does not redirect?
I realise that this is not a 'normal' shop - I have multiple items added to the cart from various product options (which works OK) and the UID is generated from a concatenated query field.
Can you shed any light on this please?
I expect it will be a simple matter for you but I can't see it I'm afraid.
File attached.
Thought that this would be the simplest bit!
Many thanks
Steve
in the server behaviors list, double click the Checkout button server behavior and set the redirect to point to the checkout page.
steve287725
That's already done
Jason
That's already in place . . .
Steve
steve287725
Hello Jason - any movement on this please?
Steve
i have sent you a skype contact request, send a skype message when you see me online and we can look into the issue.
