Can't get SA genorated form to validate Unique Databas value in update form
Thread begun 10/28/2011 8:10 pm by doug.lemesurier305760 | Last modified 10/31/2011 7:37 am by Jason Byrnes | 1254 views | 1 replies |
No mater what I do, I can't seem to Update a user record if I am using the Unique Database Value validation behaviour. I just generate the SA registration forms. I have selected to use Unique Database values on the email and userid fields.
When I try the update form to change the last name filed, the form reports the the userid is already in the system on the record does not update.
This means a user may not update there own info.
Not sure if I am explaining this well be I am 5hrs into it now and I can't figure it out.
Any advice?
Cheers
Doug
The .UsserID value should not be an updateable value.
the userID column of your database should be the primary key column which should be set to auto increment meaning the database engine will manage the value for that column.
the user ID should not be included as an updateable field in the users profile page, it should not be able to be changed by the user.
when the user logs in, the UserID value is stored in a session, this session is used throughout the site to identify the user, if they where to change that value, it would no longer match the session value, the user would need to log out, then log back in to be able to access their content.
Better of leaving the database to manage that column and not let the user update it.
