Update after Insert
Thread begun 10/28/2011 10:30 am by anthony399409 | Last modified 11/01/2011 12:41 pm by Jason Byrnes | 7082 views | 10 replies |
anthony399409
Update after Insert
My form has several form fields, one of which is a select menu identified as 'State'. After submitting this form it will take the user to the next page where they will select their 'Location' based on their 'State'.
However, I'm having trouble getting the entry's ID to pass thru the URL to update the entry. I've been able to pass the 'State' entry with the URL and pull the 'Location' selections in, but that was by building a form outside of the WADA system. When I use the WADA system to build the forms I get the 'No Record Found' result.
If you want to see what I'm trying, you can go to ads_Insert.php
Send a copy of your page and a screen shot demonstrating the problem in a zip archive, the link you provided is not working.
anthony399409
I may have typed the URL wrong - ads_Insert.php
you shouldn't be going directly form insert to update.
The data assist wizard will create a search and results and details page along with the insert, update and delete pages, the insert page should redirect to the detail page which will show the details of the record just inserted, from there, you can select to update it or delete it.
anthony399409
I figured I would have to do that. I was wanting to eliminate an extra click for the end user. I used the ADDT for this the last time around, but since there is no more ADDT, the support for it is mostly gone.
When I used the ADDT I was able to pass the newly inserted record's ID to the next page, but this one isn't working the same way.
Thanks for the reply!
If you look at the code for an insert, you will see that the redirect URL is created before the record has been inserted. It cant use the ID of the record that will be inserted in the redirect, because that value cannot be know yet, it can only be known after the record inserts.
If you look further down the code, you will see this line after the code to perform the insert:
$_SESSION[$WA_sessionName] = mysql_insert_id();
This code stores the inserted records ID into a session variable.
further up the code, you will see a line that sets the $WA_sessionName variable, it will look something like:
$WA_sessionName = "WADA_Insert_visitors";
this sets the name that will be used for the session:
$_SESSION['WADA_Insert_visitors']
if you want to go directly to the update page from the insert, you will need to leave the redirect in the insert behavior blank, then add code after the insert to perform the redirect using the newly created session variable in the URL.
Add this code just after the insert record behavior.
if($_SERVER['REQUEST_METHOD'] == "POST") {
header("Location: ads_Update.php?id_ad=".$_SESSION[$WA_sessionName]);
anthony399409
That worked perfectly! I was trying to write that, but was unsure about the $_SESSION part of it.
One day I'll know php much better.
anthony399409
I was wondering if I needed URL parameters in the $WA_redirectURL function?
no, you wont be able to use the $WA_redirectURL since this is set before the record is inserted.
you need to leave that blank, then do the redirect manually after the record is inserted to be able to use the session.
keep in mind PHP is executed from top to bottom.
where the $WA_redirectURL is set before the code to insert the record, the session does not exist when it gets set, it only exists after the record is inserted.
anthony399409
Not sure what I've done, but it was working fine yesterday and now it isn't.
I'm attaching the insert file so you can see the code.
