Capturing logout from timeout
Thread began 10/28/2011 9:53 am by sharon39426 | Last modified 11/01/2011 6:26 am by Jason Byrnes | 1517 views | 5 replies |
sharon39426
When a user logs out by clicking a logout button, I am able to capture the logout event and send it to my audit trail data table. I also need to capture the logout event when the user is logged out due to timeout. Where is this event stored? Any information you can provide to help me send the logout event to the database would be appreciated. I'm using classic asp with a SQL database.
Thanks!
see the following post on stackoverflow:
design-classic-asp-applications-to-detect-session-expiration-dynamically
sharon39426
Need to capture the event and record in an audit trail.
Thanks, but the link only shows how to timeout the session. My user is already being logged out, I just need to record this event to the audit trail data table. Right now I show a bunch of logins but no logouts if the user is logged out because the session has timed out. I need to show that each one who logged in also logged out. Since the user is not clicking a logout button (which I can capture), how can I record the logout to my audit trail?
Thanks!
no, the link shows you a script that will start a counter on page load to check if it is idle long enough to trigger the session time out, then redirect to another page:
<head>
function redirect(url) {
window.location = url;
function beginSessionTimer() {
// 30000ms = 30s
window.setTimeout(redirect, 30000,
"http://www.yoursite.com/login.asp?session=clear");
</script>
</head>
<body onload='beginSessionTimer();'>
</body>
on the login.asp?session=clear" use the session=clear qurystring variable to trigger the update to mark the user as logged out.
sharon39426
how does that store the logout in the database? the user is already being logged out, I don't need to create a counter and log them out, they are already getting logged out. I just need to record the logout event to the database.
the point is that when the counter reaches 0, they are logged because the session has timed out.
So this script redirects to a page where you can update the status in your database.
I understand that the user is already logged out, but your using the script to redirect to a page where you can act on that fact
you need to add the Update record behavior to the page that script redirects to to update the status in the database.
the script is giving you a way to create a session timed out trigger, you need to create the page that will act on it.
