Add a PowerGallery 2 gallery to a Power CMS page
Thread begun 10/27/2011 7:02 am by Rune Brynestad | Last modified 2/08/2012 7:14 am by Jason Byrnes | 10273 views | 5 replies |
Rune Brynestad
I want to add a gallery to a power cms page. I hav used the "Database Integration Update" from the Power Gallery 1 download page (Strange that this is not included in PowerGallery 2).
I have uploadad the wa_evaluate.php file from the PowerGalley 1 Database integration update to my site.
I have used this code in the CMS content area:
<input id="1" name="powergallery" theme="Av Moster" type="hidden" value="/kunder/totalweb.no/www/kunder/avmoster/gallery/galleries/grid_lightbox/index.php" />
and finally edit my output the cms content to
<?php require_once("wa_evaluate.php"); ?>
<?php echo wa_evaluate(WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'Costa Blanca - Orihuela Costa', 'Hoved')); ?>
On my page I have this error message:
Fatal error: Cannot redeclare wa_evaluate() in /kunder/totalweb.no/www/kunder/avmoster/wa_evaluate.php on line 2
You can see it on live URL here:
costablanca.php
I'm attaching my pages costablanca.php and wa_evaluate.php
Regards
Rune
remove this line:
the wa_evaluate function is already defined in another file and does not need to be re-declared.
Rune Brynestad
It's displaying on the page now, but not in the way I want. Look at:
costablanca.php
and here is what should have been embedded:
index.php?gallery=1&theme=Av%20Moster
As you can see ther's also some notice and warnings on the costablanca.php page
Notice: Undefined variable: database_PowerStoreConnection in /kunder/totalweb.no/www/kunder/avmoster/WA_CMS/library.php on line 118
Warning: opendir(/kunder/totalweb.no/www/kunder/avmoster/WA_Globals/galleries/grid_lightbox/css/themes) [function.opendir]: failed to open dir: No such file or directory in /kunder/totalweb.no/www/kunder/avmoster/gallery/admin_gallery/common/functions.php on line 490
Notice: Undefined offset: 0 in /kunder/totalweb.no/www/kunder/avmoster/gallery/galleries/grid_lightbox/index.php on line 40
I'm uploading a new copy of the costablanca.php page
Thanks in advice.
Regards
Rune
JamieEff
Just found this thread and think that my post earlier today may be connected? showthread.php?p=119425#post119425
in the other thread I sent you an updated copy of the admin_gallery/common/functions.php file that should correct the problem.
JamieEff
Hey JAson
Am trying to get the following to be able to add to a PCMS editor
$pg_id = '3';
$pg_theme = 'Past Events';
include('/home/rallywb6/public_html/gallery/galleries/grid_lightbox/index.php');
So far I have got:
<input id="1" name="powergallery" theme="Past Events" type="hidden" value="/home/rallywb6/public_html/gallery/galleries/grid_lightbox/index.php" />
<?php echo wa_evaluate(WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'xxx', 'xxx')); ?>
I am not sure what to put in the xxx as the information is being held in a table that isnt pcms......
??Do you mean a recordset?
if so, then use the recordset binding
JamieEff
I have created this
div class="pastEventRHS">
<h2 style="margin-bottom:-20px;"><?php echo $row_Event['EventYear']; ?> Gallery</h2>
<?php echo $row_Event['Event Gallery']; ?>
</div>
And I want to allow my client to be abnle to add a gallery through an HTML editor in the back end but I dont knwo which bits to use where.....
so, you use this code on the page to display the gallery?
to add the gallery in the back end, the user would add the following in code view of HTML Editor:
then change the code to display the gallery:
echo wa_evaluate($row_Event['Event Gallery']); ?>
NOTE: You may need to adjust the path to the wa_evaluate file.
