Removing unwanted fields from form
Thread begun 10/26/2011 9:24 pm by rmruda390861 | Last modified 10/27/2011 12:49 pm by rmruda390861 | 2261 views | 4 replies |
rmruda390861
OK I've read the threads on this.
I need to remove these fields from the end of the email form (which arrives when the form is submitted)
HiddenFields fields:
YourDentalRep submit:
Now I have managed to remove the first field (HiddenFields fields) this is my code:
$remove = array();
$remove[] = "";
$remove[] = "x";
$remove[] = "y";
$removeBegins = array();
$removeBegins[] = "Security";
$removeEnds = array();
$removeEnds[] = "_x";
$removeEnds[] = "_y";
$removeIncludes = array();
$removeIncludes[] = "Security";
$removeIncludes[] = "HiddenFields_fields";
Now I've tried to add:
$removeIncludes[] = "YourDentalRep_ submit";
or
$removeIncludes[] = "submit";
Neither works..
Please advise.
Richard
it looks like you have a space between the underscore and the "submit" try using:
$removeIncludes[] = "YourDentalRep_submit";
if it still does not work, send a copy of the form please.
rmruda390861
Hi Jason,
Thanks for the reply - actually the space was a typo in the forum (late night)
I have zipped up both php files.
Thanks,
Richard
YourDentalRep_submit is the full name of the form element, so add it to the remove array:
$remove = array();
$remove[]  = "";
$remove[]  = "x";
$remove[]  = "y";
$remove[]  = "YourDentalRep_submit";
rmruda390861
Thanks Jason,
It worked just fine - I think I get it now.
Richard
