Image upload used to work fine. Now not displaying image on page.
Thread begun 10/25/2011 4:19 pm by LWag48648773 | Last modified 12/09/2011 9:45 am by Michelle141190 | 6601 views | 11 replies |
LWag48648773
I have an Insert item form with image upload that has been working for probably well over a year but suddenly something is wrong. I didn't change anything in the pages. Image file seems to upload just fine. I can see it on the server but it won't display on page. Yet all other images display on page.
Has something changed on your end that could possibly cause this? Or was there an upgrade that I don't know about? I just can't figure this out. Is very strange.
Here is a page. You will see item 'atest' has no image.
artsCrafts.php
CraigRBeta Tester
Looks like the image file isn't at the path specified.
if i browse the page, there appears not to be an image (map_1.jpg) for atest in the CatImages folder.
LWag48648773
Where are you seeing that Craig? Image is on server. I double checked. Images are uploading. Path in my code hasn't changed. Nothing has changed in database. Nothing should have changed in any of my code since it was working. I can see the file name in the database. If I right-click and get image info, I can see file name. I even checked my style sheet but if something got messed up with a style, then all the images would be messed up. It's really not making any sense. That's why I started to wonder if something could have possibly changed with the web assist program. That doesn't really make sense either but I didn't know what else to think. I hope someone can see something I can't because I really don't have time to take this all apart and start over!
thank you!
CraigRBeta Tester
in chrome, (or firefox with firebug installed), i pressed f12
all I did was work through the page to the relevant section, you can see it is looking for the image file in the path shown, but can't find it.
if you look at the section above with the stamp set, the image is found.
From this, I made the assumption that the file is not in the specified folder
send a copy of the Insert item page so we can look at the code to begin troubleshooting the problem.
LWag48648773
Files attached
Thanks Jason - I also attached the display file. Let me know if you need anything else.
1) the ini_set code you have at line 25 - 28:
ini_set
('memory_limit','500M');
should be moved to line 1.
2) Just before that code block add this code block:
error_reporting
(E_All);
3) change this line:
$WA_redirectURL = "Catalog_Insert.php";
$WA_redirectURL = "";
4) Add this code just after the <body> tag:
<?php echo WA_DFP_AllUploadsDebug(); ?>
this will write debuging info to the screen, post back the results after trying to upload a file.
LWag48648773
results
Status object: WA_UploadResult1
statusCode : 1
errorMessage :
clientFileName : map.jpg
fileExtension : jpg
serverFileName : map_3.jpg
serverSimpleFileName : map_3
serverDirectory : /home/content/w/e/b/websbywagner/html/fay/CatImages/
contentType : image/jpeg
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed : 1
fileSize : 10724
isImage : 1
imageWidth : 250
imageHeight : 162
WA_UploadResult1_1:
fileExtension : jpg
fileSize : 10724
imageWidth : 250
imageHeight : 162
isImage : 1
fileWasSkipped :
fileWasRenamed : 1
statusCode : 1
Michelle141190
I think this is the same problem that I am having. The file is uploaded, but it is not given view permissions. The permissions are set right on the folder, but the uploaded file is not inheriting them. The code used to work, but suddenly stopped.
When I upload a file using FTP, the file has the correct permissions and can be seen on the site. When it is uploaded using DFP, it cannot be seen on the site.
Any thoughts?
