Insert page returns error 'Duplicate entry '0' for key 'PRIMARY''
Thread begun 10/24/2011 7:49 am by CheopisIV | Last modified 2/23/2012 6:47 am by Jason Byrnes | 13255 views | 16 replies |
CheopisIVBeta Tester
Hello, I'm using Security Assist to develop a multi-tiered user system, and it's been a huge time saver and flawless until today (Great plugin!!).
I've added some different viewable fields for user levels and also added some spry validation to make sure data is entered correctly. Today, I'm testing the Insert User function and keep getting this error;
so my script isn't checking and advancing the User ID any more. I haven't edited the main script so I don't know where it's been broken or what caused it. I'll attach the file I'm using if anyone can assist me with it.
the VisitorID column of your database should be set to be an Auto Increment key to force the database to give it a value.
this error happens whens you do not set the primary key column to auto increment.
Just found that myself as well, thanks for the quick response. I must have accidentally changed it in my modifications of the db. Code and Plugin are still working flawlessly!
erinlima318673
Having the same issue - the extension has worked flawlessly for months - until today.
I get an error message that reads: Duplicate entry '127' for key 1
The id is set to auto increment and is set as the primary.
Nothing has changed in the db but it just stopped working.
please send a copy of the page.
erinlima318673
Insert page returns error 'Duplicate entry '0' for key 'PRIMARY'' Reload this Page
see code for Insert page below:
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<title>Insert usedbikes</title>
<link href="WA_DataAssist/styles/Refined_Pacifica.css" rel="stylesheet" type="text/css" />
<link href="WA_DataAssist/styles/Arial.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div class="WADAInsertContainer">
<form action="usedbikes_Insert.php" method="post" name="WADAInsertForm" id="WADAInsertForm">
<div class="WADAHeader">GP Motorcycles Major Unit Inventory: Insert Bike Details</div>
<div class="WADAHorizLine"><img src="WA_DataAssist/images/_tx_.gif" alt="" height="1" width="1" border="0" /></div>
<table class="WADADataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th class="WADADataTableHeader">New or Used:</th>
<td class="WADADataTableCell"><table>
<tr>
<td width="72"><input type="radio" name="new_or_used" value="New" />
New</td>
</tr>
<tr>
<td><input type="radio" name="new_or_used" value="Used" />
Used</td>
</tr>
</table></td>
</tr>
<tr>
<th class="WADADataTableHeader">Model Year:</th>
<td class="WADADataTableCell"><input type="text" name="modelyear" id="modelyear" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Make:</th>
<td class="WADADataTableCell"><input type="text" name="make" id="make" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Model:</th>
<td class="WADADataTableCell"><input type="text" name="model" id="model" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Description:</th>
<td class="WADADataTableCell"><input type="text" name="description" id="description" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Mileage:</th>
<td class="WADADataTableCell"><input type="text" name="mileage" id="mileage" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Stock Number:</th>
<td class="WADADataTableCell"><input type="text" name="stocknumber" id="stocknumber" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Price:</th>
<td class="WADADataTableCell"><input type="text" name="price" id="price" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Status:</th>
<tr>
<td width="114"><input type="radio" name="status" value="In Inventory" />
In Inventory</td>
</tr>
<tr>
<td><input type="radio" name="status" value="Sold" />
Sold</td>
</tr>
</table></td>
</tr>
<tr>
<th class="WADADataTableHeader">Image Source URL:</th>
<td class="WADADataTableCell"><input type="text" name="image" id="image" value="" size="32" /></td>
</tr>
</table>
<div class="WADAButtonRow">
<table class="WADADataNavButtons" border="0" cellpadding="0" cellspacing="0">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="image" name="Insert" id="Insert" value="Insert" alt="Insert" src="WA_DataAssist/images/Pacifica/Refined_insert.gif" /></td>
<td class="WADADataNavButtonCell" nowrap="nowrap"><a href="usedbikes_Results.php" title="Cancel"><img border="0" name="Cancel" id="Cancel" alt="Cancel" src="WA_DataAssist/images/Pacifica/Refined_cancel.gif" /></a></td>
</tr>
</table>
<input name="WADAInsertRecordID" type="hidden" id="WADAInsertRecordID" value="" />
</div>
</form>
</div>
</body>
</html>
i need the full page, not just after the doctype, i need the code that does the insert to.
compress the php file into a zip archive and attach that with your replay.
erinlima318673
that makes more sense - see zipped file attached.
to help troubleshoot, change the following line of code:
$MM_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
$MM_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error()."<br />".var_dump($_POST)."");
this will write the sql top the screen causing the error to help us see whats going wrong.
erinlima318673
changed that line to the one you sent and rezipped the file. see attached.
