Powergallery V2 does not work properly!!
Thread begun 10/23/2011 6:16 pm by Fernando Tuzzi | Last modified 3/01/2012 2:31 pm by biz295654 | 7227 views | 19 replies |
Fernando Tuzzi
Does not work properly, then bypass several obstacles during the installation with session management problems Finally I could install install it with the help of my hosting support.
Now I have crated a gallery but the style of the theme selected appears broken and in the admin panel when I try to view the preview of te lected theme this appear as blank page.
Here are the link:
cuero.php
Please a need a solution ASAP!!!
in the webassist/caching/PG_CachedResize_Image.php file.
change line 14:
$retVal = is_dir($pathname) || @mkdir($pathname, 0777);
$retVal = is_dir($pathname) || @mkdir($pathname, 0755);
and line 360:
mkdir ($cachefolder,0777,true);
mkdir ($cachefolder,0755,true);
also, make sure that the permissions on the powergallery/images/ folder and all files and folders under it are set to 755
Fernando Tuzzi
I have made all the changes that you suggested but still not working :mad:
Fernando Tuzzi
biz295654WebAssist
I purchased a second license for PG after checking with Jason exactly what to do with my server set up and all is good. I do think Safari cache has an issue, but if using another browser for editing in the system, all is good. So this is what I did to make for my particular server, per Jason's patience.
On some servers the permissions for the gallery and webassist folders and
all files and folders underneath need to be set to 755, and the
webassist/caching/PG_CachedResize_Image.php file needs to be updated to
change line 14:
and line 360:
From my experience... maybe it will help
And the admin_gallery/common/properties.php file needs to be edited to
change:
$GLOBALS['permissions'] = array(
'dir' => 0777,
'file' => 0666
To:
'dir' => 0755,
'file' => 0755
Thank you Jason for explaining it for me so I can address. Very much appreciated.
biz295654WebAssist
A new install of PG is giving me the same permissions issue. I changed the 777 references in webassist/cashing/PG_CachedResize_Image.php file on line 14, 360 and in common/properties from 0777 / 0666 to 0755 etc.
But still no luck. Is there another 777 setting I need to address?
using filezilla, change the permissions on the gallery folder and folders and files underneath to 755.
if the files are already created with 777 permissions, the code change wont reset them, that needs to be done manually in filezilla or another dedicated FTP program.
biz295654WebAssist
I found this one too:
unction deleteDirectory($dir) {
if (!file_exists($dir)) return true;
if (!is_dir($dir) || is_link($dir)) return unlink($dir);
foreach (scandir($dir) as $item) {
if ($item == '.' || $item == '..') continue;
if (!deleteDirectory($dir . "/" . $item)) {
chmod($dir . "/" . $item, $GLOBALS['permissions']['dir']);
chmod($dir . "/" . $item, 0755);
deleteDirectory($dir . "/" . $item);
I did check folders and they are set to 755 ...Using Transmit to look at them. I'll double check again. Thanks.
biz295654WebAssist
Well, they all look like they are set to 755.
I can reverse what I did and then set the folders to 777. Would that solve it?
biz295654WebAssist
Before I try that, take a look please at a test using the include. Click in the middle of the page.
testgallery.php
