Turning Static into Dynamic Pages
Thread begun 10/21/2011 11:05 am by goat200487425014 | Last modified 10/21/2011 3:38 pm by goat200487425014 | 2627 views | 5 replies |
goat200487425014
So right now I have static pages, is there any way to keep my exact layout and just add the echo commands to certain areas, like price, product name, product description so when I add to cart, i still get the same outcome?
yes, create the recordsets to lookup the dynamic data, then add the bindings from the recordset where the dynamic data should be displayed.
goat200487425014
I have tried it and some fields show the wrong product name and picture. How exactly does the echo command know what product I am wanting. Should I include exact links to products that I want like:
<img id="WADAPageHeaderImage" src="../inventory_images/detail/red.jpg/<?php echo $row_WADAproducts['ProductImage']; ?>" alt="" />
.....also, can I use the same tags that I had <div id="Bigpicture"> or should I use the dataassist tags <div id="WADAPageHeaderImageArea">?
you need to filter the recordset to get the correct record.
if this is a product detail page, the link to the detail page will contain a URL variable to pass the product iD:
productDetails.php?productID=4
in the recordset, set it to filter the product id column on the productID URL variable.
you can use whichever id makes your page look the way you want it to.
goat200487425014
Is this what it should look like?
goat200487425014
NVM, figured it out. My extension didn't match the one I had in the database....thanks jason
