Errors again - why?
Hello,
It seems that whenever I use Contact Form Builder and simply go through the wizard, errors appear.
Anyone know why this error appears? Again, I fill in the wizard but for some reason errors occur.
SendYourReview.php
Hello,
SendYourReview.php
send a copy of your SendYourReview.php page so i can see the code, I cant tell why the error is happening without seeing the code.
Hello,
Here's the zip as requested.
ok, the problem is with the code for the validation show if behaviors. you can fix it by going to the server behaviors panel, double clicking each validation show if, and re selecting the condition that should be used to trigger the validation error.
What version of Form Builder are you using? Make sure that you have installed the most recent version that is available in the download center. For Version 2, make sure to use the 2.0.1 Support Release 2 version available in the Support Release section of the Form Builder download center page. If you have a previous version installed, make sure to uninstall it from the extension manager before installing the newer one.
Hello,
I uninstalled FB2 and installed FB2.1.
I went to the server behaviours panel where there were some exclamation marks next to around 6 lines of text. I clicked on one and all the exclamation marks disappeared.
I uploaded the page again but it still doesn't show. It displays an error.
Have I missed something out?
It would be better to recreate the page, just editing one of the validation show if behaviors will not correct them all.
Hello,
Thanks for your patience.
I've re-run the wizard without making any changes and it now works.
