Multiple Site Search?
Thread begun 10/19/2011 11:01 pm by jenmerie431472 | Last modified 10/31/2011 1:10 pm by Jason Byrnes | 6937 views | 15 replies |
jenmerie431472
Hello,
First, I just want to thank you for creating this application to help the less programming savvy. I also appreciate that this tool is free. (Going to recommend this site to friends!)
I was able to successfully create the search engine, but I was wondering if there was a way to search more than one site. Let's say for instance, I have two webpages covering two different topics (on seperate domains), but I want the user to be able to search both and only those two?
I'm pretty sure I can't add a second link in the Wizard, but I did open up the javascript file. I saw the variable bing_sites , is there a way to add another link there somehow? I tried everything, I even went as far as creating another variable called bing_sites2. I went to the encodeURIComponent section and added my second variable in the parenthesis with a + and it still didn't work.
I would really appreciate help on this one. Thank you!!!
in the webassist/bing/bing_search_tk.js file, you would need to edit the bing sites variable to include the second domain using an OR separator, for example:
var Bing_sites = "www.yourdomain.com";
would need to be changed to:
var Bing_sites = "www.yourdomain.com OR site:www.yourOtherDomain.com";
info396563
Hi Jason
Can you add multiple websites via this method so that there will be search results from more than one website?
Scott
yes, you can add more OR site:newdomain to add more sites to the search.
jenmerie431472
Thanks for the info!!
jenmerie431472
Quick Question..
I added it the way you suggested, It does include both sites when I search, but it doesn't seem to search for the keyword. It displays results, but its not the results I searched for. Any suggestions? Thanks again!
are you sure it's not the results you searched for? The Bing Search engines searches on the page content, the pages meta keywords tag, the pages description tag and the title.
Can you send a link where i can test this? What is the search term you are using?
info396563
Just so I can understand this properly, if I change the JavaScript to read like the example below this would then provide search information on those sites on my search results page?
var Bing_sites = "www.bbc.co.uk OR site:www.sky.com OR site:www.webassist.com";
Scott
yes, that is correct Scott.
info396563
Thanks Jason
regards
