Facebook LIKE dynamic option produces error
Thread begun 10/19/2011 5:56 pm by ShorePatrol | Last modified 10/20/2011 1:25 pm by Jason Byrnes | 2487 views | 3 replies |
ShorePatrol
If I insert a FB Like feature using the "use current page" option, when I view the page I see:
" send="false" layout="standard" width="150" show_faces="false" action="like" colorscheme="light" font="">
followed by the FB button...
Seems to work fine if you specify a page, but the dynamic feature isn't working. (my page is an ASP page)
Please advise.
Thanks!
The currant page option uses PHP code, it wont work in an asp page.
the server will not process php code that is added to an asp page.
ShorePatrol
Please explain 2 things
Jason,
If that's the case, then I'm a bit miffed, and I have another question.
I'm angry because your "System Requirements" for this product do NOT state that you need PHP:
system-requirements.php
In fact, in the requirements is says "Works with static, dynamic or template pages" - I knew you guys dropped ASP support a while back, so I called your sales department - I was told this product would work with ANY dynamic page (as your requirements say). If it doesn't support ALL dynamic pages, then your requirements should state that.
If this is the case, that it won't work on an ASP page, then why can I use the SHARE buttons, using the "use current page" feature on an ASP page and it works fine?
Ok, just took a closer look at the code - I can easily replace the PHP code to ASP and make it work, and I see that the SHARE buttons are javascript based, which is why they work on ASP pages.
I still think you should list PHP being a requirement for ALL your products...it's a bit shady to say it works with dynamic pages, and that say later, only certain ones...my 2 cents.
I have forwarded your comments to our webmaster and the system requirements will be updated to reflect PHP only.
