Setting Site Dimensions via Siteassist Pro
Thread begun 7/14/2009 9:48 am by tirzahm338096 | Last modified 7/14/2009 11:59 am by Ray Borduin | 2859 views | 3 replies |
tirzahm338096
What am I missing - is there a way to change my site dimensions within Siteassist Pro? Is the default 800 x 600, is there a easy way of setting it to 1024x768?
Thanks in advance.
You could update your template after it is created, or create a template with the correct dimensions first and use that... there is no way to change the dimensions from within that interface itself.
tirzahm338096
so i have to adjust and resize all of the images as well i guess? oh joy :)
Since 800x600 monitors is fast becomes less and less common and decreasing in market share (only 4% on marketshare.hitslink.com) are there any thoughts or plans on Webassists end to change the default web page dimensions. All of the pages i am building these days are at least 1024 x 768.
Yes. There has been recent discussion about making that change, so you will see it as products are updated.
