Force the checkout.php page to http instead of https
Thread begun 10/12/2011 1:34 pm by Rune Brynestad | Last modified 10/14/2011 12:01 pm by Jason Byrnes | 4182 views | 3 replies |
Rune Brynestad
I does not use any payment gateway, so my site does not make use of a SSL certificate. Nevertheless the checkout page try to access the https protocol.
To force the checkout.php page to use http instead of https, I have tested this 3 code blocks at line 1 one by one for the checkout.php page
<?php if (isset($_SERVER['HTTPS']) && strtolower($_SERVER['HTTPS']) == 'on') header("Location: http://".$_SERVER['HTTP_HOST'].$_SERVER['PHP_SELF']); ?>
<?php if(((isset($_SERVER['HTTPS']))) && ($_SERVER['HTTPS'] != "") || ($_SERVER['HTTPS'] == "on"))header("Location: http://" . $_SERVER['HTTP_HOST'] . $_SERVER['PHP_SELF']); ?>
if((!(isset($_SERVER['HTTPS']))) || ($_SERVER['HTTPS'] == "") || ($_SERVER['HTTPS'] == "off")) {
header("Location: https://" . $_SERVER['HTTP_HOST'] . $_SERVER['PHP_SELF']);
die();
The checkout.php page is not redirected to http as expected.
Please help.
You can test my site on live URL here: www.totalweb.no
The site is translated to norwegian, but I think you should be able to find the exact buttons.
Regards
Rune
in the webassist/plugins/shopping_cart/checkout_form.php file, change:
if (empty($_SERVER['HTTPS'])) {
  $testRedirect = "https://".$_SERVER['SERVER_NAME'].$_SERVER['REQUEST_URI'];
  $c = curl_init();
  curl_setopt($c, CURLOPT_URL, $testRedirect);
  curl_setopt($c, CURLOPT_TIMEOUT, 90);
  curl_setopt($c, CURLOPT_SSL_VERIFYPEER, 1);
  curl_setopt($c, CURLOPT_SSL_VERIFYHOST, 1);
  $result = curl_exec($c);
  if ($result)  {
      header("location: ".$testRedirect);
      die();
/*if (empty($_SERVER['HTTPS'])) {
  $c = curl_init();
  if ($result)  {
      die();
Rune Brynestad
Thanks for helping me on this.
I also have problems with foreign characters encoding under Billinginfo for the cart.php and checkout_success.php pages.
Rune Brynestad
Skårer Terrasse 13
1473 Lørenskog
should have been
Rune Brynestad
Skårer Tarrasse 13
1473 Lørenskog
The cart.php and checkout_success.php pages are the only files in Powerstore 4.5 I have this problem. I use
for all my pages. I also use utf-8 for my database connection and utf-8 as the database encoding type.
Regards
Rune
