PS4.5 missing Content Menu Items
Thread begun 10/11/2011 2:04 pm by info385819 | Last modified 10/24/2011 8:33 am by Jason Byrnes | 3584 views | 5 replies |
info385819
Hello,
When admin. goes to ( CONTENT ) the menu on the left shows the CMS selectable fields available for editing. The store suddenly has removed some of the selections and they are no longer available for editing selection from the menu? Please see attached screen shot image showing correct menu selections on left and the suddenly missing items on right.
Thank you for your help in resolving this.
the only way to fix this will be to delete the entire content table and recreate it from scratch.
use the attached content.sql file to recreate the ps4_contents table.
info385819
RE: content Error PS 4.5
Hello,
Do you have instructions on how to make this change using your file supplied?
see the "How to import a MySQL" tutorial on the learning resources page:
resources.php?utm_campaign=Forum_header&utm_medium=Forums&utm_source=WebAssistForums
info385819
ps45 admin content menu missing
We applied the update for the content file provided. The menu returned but, now The content selection menu on left has no action when selecting a menu item. The content areas are only accessible through the home page by clicking on a editable field while logged in but, when you access the editable field the editing options menu normally present to change details without using source code are not available or showing. Admin will only see a empty box with straight text. Please advise how to fix , thank you.
