SiteScribe
Thread begun 10/11/2011 6:49 am by latellogroup375248 | Last modified 10/12/2011 7:39 am by Jason Byrnes | 1487 views | 1 replies |
latellogroup375248
SiteScribe
I haven't used the SiteScribe in a while. When I go to export to a pdf it tells me that I need to have a copy of Java version 1.4. Is there a file to fix this so that it will use a more current version of Java? If not is there another way that I can still print my entire site to a pdf? Thank you in advance for you help
when you get that error message, if you click OK, you will be able to specify the location of the java runtime version to use.
Click the folder icon and browse to the location that you have installed Java 1.4 or greater to.
