Upload 2 field in Update page not working
Thread begun 10/10/2011 3:44 pm by morganbeat297916 | Last modified 10/11/2011 7:44 am by Jason Byrnes | 1498 views | 1 replies |
morganbeat297916
I created page from DataAssist and setting upload 2 field in page. "Insert page" is fine but "Upload page" work only first selected upload field
id
*photo field
title
desc
date
*file field
If select photo field first. It working only photo field
there are a few problems on your page:
1) in the Upload Files (file_dl2) server behavior, you have set the default file setting to use the file_dl of the WADAdownload recordset, it should be set to use the file_dl hidden form element instead.
2) in the Upload Files (up_photo) server behavior, you have set the default file setting to use the img_dl of the WADAdownload recordset, it should be set to use the img_dl hidden form element instead
3) in the update record behavior, you have bound the img_dl column to the img_dl of the WADAdownload recordset. Click the lightning bolt next to it, from the bindings panel, expand the Uploaded Files (up_photo) binding group and select the Server File Name binding.
