Form Processing for Goldmine WebImport
Thread begun 10/10/2011 1:35 am by John.Legg345160 | Last modified 10/13/2011 5:26 pm by randyw2394710 | 1927 views | 2 replies |
John.Legg345160
I would like to use CSS Form Builder 2 as a front end for capturing customer enquiries etc. The form data then needs to be sent via Email to our Goldmine CRM system.
The format of the email s defined by Goldmine so that the customers contact information can be added automatally within Goldmine when the email is received.
Can anyone suggest where in CSS Builder 2 I can add the code for formatting the email from the data entered by the user?
John
If you have already created the form, and already set it up to be emailed, go to the server behaviors panel (Window -> Server Behavior) and double click the universal email server behavior.
since you need to use a specific format, do not select the Create a File For the Email option, instead, click the DW Edit button to create the email in Dreamweaver.
You can use the bindings panel to add the form bindings to the email.
randyw2394710
All set thanks
