having trouble setting the initial zoom
Thread began 10/09/2011 7:51 pm by JBWebWorks | Last modified 12/06/2011 7:43 am by JBWebWorks | 3038 views | 10 replies |
JBWebWorks
here is my page
store-locator.php
Used the info from support on how to set the zoom and have added this line to
wagmp_map_1.php 3different places.
map.setZoom(5);
When the page loads in browser (checked IE 9, firefox, chrome and IE compatibility view)
the zoom is correct for a second and then it changes to the least zoom viewing the US.
thanks for your help,
-Jim Balthrop
JBWebWorks
Disregard my previous post, i found the solution in another post concerning the permissions for directory, _promaps_cache.
Once i set the correct permissions, the page with the map starting loading faster and the zoom setting is now corrected.
-Jim Balthrop
JBWebWorks
I spoke too soon; i am now having the same problem. Not sure if it is the zoom setting, my DB structure or my recordset.
here is my page
store-locator.php
I have 2 recordsets from the same table. 1 supplies the map, the other populates a repeat region with the store listings.
the map recordset-
mysql_select_db($database_connsecret, $connsecret);
$query_rs_storelocation = "SELECT store_locator.store_name, store_locator.store_address, store_locator.store_city, store_locator.store_state, store_locator.store_zip, store_locator.store_phone, store_locator.store_active FROM store_locator WHERE store_locator.store_active = 'yes'";
$rs_storelocation = mysql_query($query_rs_storelocation, $connsecret) or die(mysql_error());
$row_rs_storelocation = mysql_fetch_assoc($rs_storelocation);
$totalRows_rs_storelocation = mysql_num_rows($rs_storelocation);
the repeat region store listings recordset-
$query_rs_stores = "SELECT store_locator.store_name, store_locator.store_link, store_locator.store_address, store_locator.store_city, store_locator.store_state, store_locator.store_zip, store_locator.store_phone, store_locator.store_active FROM store_locator WHERE store_locator.store_active = 'yes' ORDER BY store_locator.store_state, store_locator.store_city, store_locator.store_name";
$query_limit_rs_stores = sprintf("%s LIMIT %d, %d", $query_rs_stores, $startRow_rs_stores, $maxRows_rs_stores);
$rs_stores = mysql_query($query_limit_rs_stores, $connsecret) or die(mysql_error());
$row_rs_stores = mysql_fetch_assoc($rs_stores);
I am in the process of loading more store information into the db and i started having the problem today.
Page takes a long time to load and then the zoom jumps back and forth a few times and many of the locations are not shown on the map. Not consistant that i can see.
one thing i see is in the _promaps_cache/_promaps_geocache.xml file, there is a bad tag at the end.
at the very end of that file change:
</geocode_data>
geocode_data>
</geocode_data>
when the zoom of the map starts to flicker, it usually means that there are some addresses that the google geocoder is not able to find. if the address lookup fails, this code:
if (wagmp_map_1_obj.addressFailed) {
map.setCenter(new GLatLng(30, -98), 3);
will center the map on lat long: 30, -98, using the zoom level of 3
one address i can see being a problem is:
107 Harmony Crossing No 3, Eatonton, GA, 31024
if i go to maps.google.com to search for that address, it cannot find Harmony Crossing, but it can find Harmony Rd. The google maps website will return alternates, but the geocoder will not.
JBWebWorks
thanks Jason.
I corrected the code tag in the _promaps_cache/_promaps_geocache.xml file and have tested the page in all browsers and it works fine.
The address, 107 Harmony Crossing No 3, Eatonton, GA, 31024 shows on the map as Harmony Road, so i won't change the address.
Question- what generates the _promaps_geocache.xml file and if i don't delete the file, should it ever be updated and possibly have the same bad tag problem?
If so, i can just correct it again on the server and i will know what to look for.
Thanks again, Jason
the geocache.xml file is generated by the map js file.
it is updated any time there are new addresses.
If a new address is added to the database, the map js file will connect top the google geocoder to lookup the the latitude and longitude for that address, then update the XML file so it will not need to connect to the geocoder the next time the page is loaded.
I cant say how that line got messed up to be honest, but you should be able to go to the xml file in the browser:
and not see any errors.
JBWebWorks
Jason,
I am still having problems with the XML file getting the wrong code tags.
I am not adding any more addresses at the present and have a little over 200 addresses at the present.
When i see the problem with the map zooming in and out on page load, i go to the file manager and correct the code in the XML file; always a bad tag at the bottom of the file.
I have checked the permission settings of 755.
Anything else i should check?
-Jim Balthrop
Dani Chankhour
I have created a support ticket to further debug the issue. Most Likely It is an issue with one of the addresses. I will ask for more information in the ticket.
JBWebWorks
What you did corrected the problem with that site. Thanks!
I am having a similar problem with another site but there are no special characters in the addresses for this one.
The only similarity is they are both hosted on GoDaddy and both pull locations from a recordset.
Let me know if you need the ftp access for this page
property.php
thanks,
-Jim Balthrop
when i view source of your page, i see the following code for the first address:
var address_0_0 = {
street: 'Click on Push Pins for Property Information',
city: '',
state: '',
zip: '',
country: '',
infowindow: 'custom',
infowindowtext: '<span style="font: 12px Verdana, Arial, Helvetica, sans-serif; color: black;"><strong><a href="propertydetail.php?property_ID=1"></a></strong><br/><strong>Address:</strong><br />Click on Push Pins for Property Information<br />, </span>',
full: 'Click on Push Pins for Property Information, , , ,',
isdefault: true,
addressType: 'address',
loop: 'rs_property',
latitude: '',
longitude: '',
markerStyle: 'Push-Pin',
markerColor: 'Moab'
i think this is causing the issue,
