Securityassist Registration page testing on localserver
Thread begun 10/06/2011 10:05 pm by santosh_kulkarni430459 | Last modified 10/11/2011 8:06 am by Jason Byrnes | 2788 views | 3 replies |
Hello
I have purchased Webassist Super suite and downloaded. installed and activated all the extensions including Securityassist.
I am trying to learn from your database elearning tutorial and was able to connect to database, and using Securityassist I am able to create all the php pages. But when I try to test the registration.php page on the local server, I get "Please wait" message in DW Live view and nothing happens, on Safari, I get a blank page. No user record is created in the backend pcm2_user table in the connected database
I am new to web programming and your extensions..please help
Santosh
I dont recommend using Dreamweaver Live View for testing your page, it is better to test in a Web Browser.
If a php page displays blank in the browser, it means that a php error has occurred but error reporting is turned off.
Add the following code at line 1 of the page to turn error reporting on:
error_reporting
(E_ALL);
once we know the error, we can begin troubleshooting.
Thanks Jason
After inserting your code I can see the error as follows..Please help.
Santosh
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /Applications/MAMP/htdocs/Database-Elearning/registration.php:6) in /Applications/MAMP/htdocs/Database-Elearning/webassist/form_validations/wavt_validatedform_php.php on line 3
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /Applications/MAMP/htdocs/Database-Elearning/registration.php:6) in /Applications/MAMP/htdocs/Database-Elearning/webassist/form_validations/wavt_validatedform_php.php on line 3
Fatal error: Call to undefined function WAValidateUnique() in /Applications/MAMP/htdocs/Database-Elearning/registration.php on line 19
see this post for a fix to the Call to undefined function WAValidateUnique() error.
showpost.php?p=106073&postcount=14
the other errors are caused by blank space between php code blocks, see this post for details:
showthread.php?t=19285
