Error starting floater; TypeError: MM.WA_createProcessingObject is not a function
Thread begun 10/06/2011 1:32 pm by info396563 | Last modified 5/31/2012 7:37 am by Jason Byrnes | 5808 views | 9 replies |
info396563
Hi
Can you confirm what the following two errors are please, as I and trying to build a search bar on an existing page and I keep getting the following errors:
Message 1
Message 2
While executing onShow in WA_SiteTools_ProgressV2.html, the following JavaScript error(s) occurred:
In file "WA_SiteTools_ProgressV2": initializeUI is not defined
Please can you confirm what needs to be down to correct this.
Scott
Delete the Dreamweaver Cache file from the users configuration folder:
info396563
Ok thanks Jason, I'll give that a try..
Regards
info396563
Hi Jason
I cannot find any MacFileCache.dat files, I have viewed the PDF and completed the instructions but cannot locate this file anywhere, is there another way of locating this file?
Regards
Scott
info396563
Originally Said By: info396563
  Hi Jason
Regards
Scott
Hi Jason
Can you confirm my thread above please?
thanks
Scott
bill303061
I am experiencing the first error message, but not the second one. Closed DW cs 5.5, deleted the wincache file in the configuration folder, started dw again and got the same message again.
cablackwood426030
Also getting Security Assist error message
Windows 7 dreamweaver cs5.5 - error starting floater typeerror mm.wa_createprocessingobjectv2 is not a function.
have reinstalled security assist 2.05
deleted cache
Any update on this issue
