visitor login question
Thread began 10/06/2011 12:08 pm by johna1964 | Last modified 10/08/2011 5:56 am by johna1964 | 2167 views | 6 replies |
johna1964
Hi!
My question is regarding after a person has logged in. The redirect takes the same page however with a show region of "you have been logged in, but it continues to show the login form. What do I need to change to make the form disappear after log in, but still be able to see the log in confirmation.
People are becoming confused about seeing the login again.
Thanks!
johna1964
send a copy of your login page please.
johna1964
Hi Jason,
Here is the login.php file
Thanks for your help... :)
Johna
add the following code just before the login form tag:
<?php if(WA_Auth_RulePasses("Log in success")){ // Begin Show Region ?>
so it looks like:
<form class="Basic_Default" id="LogIn_Basic_Default" name="LogIn_Basic_Default" method="post"  action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>">
then add this code just after the closing form tag:
<?php // End Show Region ?>
so it looks like:
</form>
johna1964
Jason,
I did exactly as you told me. What happened after making the change and uploading is the user trying to log in only sees the word Log In with no form to do so.
I removed the code and uploaded, so I'm back to the initial issue.
Can you see anything else that is causing the problem?
Thanks!
johna1964
sorry, this line:
[php]<?php if(WA_Auth_RulePasses("Log in success")){ // Begin Show Region ?>[php]
should be:
<?php if(!WA_Auth_RulePasses("Log in success")){ // Begin Show Region ?>
johna1964
Got it...
Jason,
Perfect! Thank you - this worked.
Johna
