Errors appear on the form page when submitted
Thread begun 10/06/2011 2:17 am by esms | Last modified 10/07/2011 4:17 pm by esms | 7160 views | 21 replies |
esmsBeta Tester
Hello,
When I fill in this page:
focussed%20listing.php
And hit SUBMIT, it appears to work but after a second or two the page populates with lines of error messages.
I worked through the wizard to build the form. I haven't edited any code anywhere, so I'm not sure what went wrong. Any ideas folks?
Cheers.
It looks like the problem in the settings for the upload folder in the File Upload server behavior.
go to Window -> Server Behaviors and double click the Upload File server behavior and double check the setting for upload folder.
esmsBeta Tester
Sorry Jason. I can't see the setting your mentioned. Please see screenshot.
send a copy of your page please.
esmsBeta Tester
OK - here it is as a Word document.
esmsBeta Tester
Sorry. It doesn't allow me to send it to you owing to it exceeding your file limit size.
esmsBeta Tester
Here it is zipped.
this zip file seams to be corrupted, i am not able to open, can you resend please.
esmsBeta Tester
Here's another try.
Thanks.
esmsBeta Tester
I think I might have sent the same file. Here's the correct one.
