PS4.5 ie9 wont load slide show gallery
Thread begun 10/05/2011 9:09 pm by info385819 | Last modified 2/28/2012 6:58 am by Jason Byrnes | 2234 views | 3 replies |
info385819
In admin Galleries all work properly with exception to " Slideshow"
This error results when trying to view or add the slide show.
Warning: require_once(../../webassist/caching/CachedResize_Image.php) [function.require-once]: failed to open stream: No such file or directory in /home/content/35/8200435/html/galleries/slideshow_wide/index.php on line 1
Fatal error: require_once() [function.require]: Failed opening required '../../webassist/caching/CachedResize_Image.php' (include_path='.:/usr/local/php5/lib/php') in /home/content/35/8200435/html/galleries/slideshow_wide/index.php on line 1
oliver244218
PS4.5 IE 9.0.8 gallery pop-up feature not working
In IE 9.0.8 gallery pop-up feature not working - images opens to a new page and you have to click back to return to the store (however it does work in compatibility mode in IE). Works in Firefox 10.
please provide a link where i can see the problem to investigate the cause.
