Arrange Form Elements
Is there a way to resize the form field... No matter what size i choose, it remains the same when published on a webpage
In the form builder wizard, you can select to use a small, medium or large text field.
you can change the dimensions of the small medium and large text fields by clicking on the customize CSS Button, form the initial select list, select Form Elements, from the second select list, select Text.
Int he size field, select each size to change the width for that size.
