Problems with Gallery, Shipping Rule and Coupons
Thread begun 10/04/2011 5:48 pm by maria386094 | Last modified 11/03/2011 11:28 am by Jason Byrnes | 4687 views | 7 replies |
maria386094
Gallery: i have made a test gallery called 'home' but cannot add it to the any content areas when i hit the 'add gallery' button in the editor.
Shipping Rule: Also i can't adjust the Max weight in the shipping rule... every time i enter 1000000 in max weight and select 'add' then 'save changes' it doesn't apply the changes and therefore the shipping cost isn't added to the order.
Coupons: I have created a coupon and when i go to add a specific product to the coupon, it doesn't add it to the coupon and the coupon is viewed as 'Products: all'.
Please help.
elgueromero13396227
I am also having the coupons reading "all" but I do not see them attached or anywhere for that matter. Any help would be great. Thanks.
in the admin/scripts/products_results.js file, change the following 2 lines:
29:
var thepage = "Update_ProductCoupons.php?Add=1&ProdID="+ProdID+"&GroupID="+GroupID;
33:
var thepage = "Update_ProductCoupons.php?ProdID="+ProdID+"&GroupID="+GroupID;
29:
var thepage = "update_productcoupons.php?Add=1&ProdID="+ProdID+"&GroupID="+GroupID;
33:
var thepage = "update_productcoupons.php?ProdID="+ProdID+"&GroupID="+GroupID;
elgueromero13396227
I changed the products_results.js and I wasn't able to see the coupon. I have the products in the coupon as it says I can remove them from the coupon. Any advice would be great.
~raw/
I'm not sure what you mean by cant see the coupon, can you send a screen shoot illustrating what you mean here in a zip archive.
elgueromero13396227
Where is the customer supposed to view and use the eCoupon code? I don't see it. I'm doing test runs to try and buy the product and use the coupon and I don't see it on any of the products. Does that make sense? I hope I'm explaining it right.
on the cart display page, after you have added items to the cart, there will be a coupon code text box to enter the coupon code:
cart.php
