Understanding Page Optimization
Thread begun 10/04/2011 5:44 am by Jonas | Last modified 5/18/2012 2:12 pm by Jason Kline | 6931 views | 13 replies |
Jonas
I do not really understand how Page Optimization in Power CMS is supposed to work. Is it intended that the meta-tags that are already entered in the template page shall be replaced. In this case they do not. When I look at the page in a browser, it's the same meta-information that is in the template page. Whereas all other information is properly replaced.
toms016390756
I use apache to rewrite my urls and meta. for SEO purposes. I do this for several websites. I always find it better to hand code everything so it more optimized.
you will need to edit the meta and title tags to use the CMS Content areas for page optiomization.
fir example:
<meta name="keywords" content="<?php echo WA_getCMSContent($database_PowerCMSConnection$PowerCMSConnection'pageName''meta-keywords'); ?>" />
<meta name="description" content="<?php echo WA_getCMSContent($database_PowerCMSConnection$PowerCMSConnection'pageName''meta-description'); ?>" />
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<title><?php echo WA_getCMSContent($database_PowerCMSConnection$PowerCMSConnection'pageName''meta-title'); ?></title>
Jonas
template based pages not work
Thanks, now it works on individual pages.
But not on the pages that I created from the CMS system that is based on a template.
These pages are completely blank.
a blank page means a php error has occurred but error reporting is turned off.
add the following code at line 1 to turn error reporting on:
error_reporting
(E_ALL);
Report back with the errors and a copy of the page so I can see the code.
Jonas
I get this error:
"<br /> <b> Fatal error </ b>: Call to undefined function WA_getCMSContent () in <b> / www/webvol16/z3/e7v7i55mki9ry4i/jonasn.se/public_html/WebAssistTst/svenska/test.php </ b> on line <b> 10 </ b> <br /> ".
The code is correct compared to the pages it works on. Also, the database is properly implemented.
Here are the code:
error_reporting(E_ALL);
<head>
<title><?php echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'Test', 'meta-title'); ?></title>
<meta name="keywords" content="<?php echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'Test', 'meta-keywords'); ?>" />
</head>
<body>
include('/www/webvol16/z3/e7v7i55mki9ry4i/jonasn.se/public_html/WebAssistTst/WA_CMS/addtosite.php');
echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'Test', 'area1', false);
?></body>
</html>
move this code:
into a php code block at line 1:
DarylBeta Tester
After inserting the code as suggested, where do you enter the page optimization information?
I have found a page within admin_cms called 'optimization', but cant find anywhere to access this from.
for each of your content pages, create new content areas named:
meta-title
meta-keyword
meta-description
SPT
Just in case someone is trying to figure out how to get the Keywords to work according to the last post (like I was).
Use:
meta-keywords
instead of:
meta-keyword
Also why isn't this in the help documents?
You should also point out that you need to be sure you edit the php code in the header of your page and change the "pagename" to what you have the page named to within the CMS editor.
And lastly - These optimizations add the <p> tag to the meta tags so be sure you go back in and edit the opening and closing <p> tags out in your CMS editor.
