Product Option ID, not name showing up in cart
Thread begun 10/03/2011 11:45 am by rachelstanley2424355 | Last modified 10/03/2011 2:49 pm by rachelstanley2424355 | 1814 views | 2 replies |
When I followed the tutorial for product options (product_options.php) it has me put the ProductOptionID in the value field and the OptionName in the label field on the dynamic drop down. This makes everything appear nice in the item page, but when it gets to the cart, I end up with numbers instead of option names. If I switch both fields to OptionName, then it doesn't add the PriceIncrement option (??).
What should I do?
change line 98:
$ATC_itemSize = "".((isset($_POST["eCart1_1_size_Add"]))?$_POST["eCart1_1_size_Add"]:"")  ."";// column binding
$ATC_itemSize = "".$row_rsSizeLookup['OptionName'] ."";// column binding
you rock! that was my last hangup before launch. *knock on wood*
