Does UE 3.07 work in DW CS5.5???
It doesn't seem to work properly.
Need to work on some UE stuff in an ASP site and 4.01 doesn't cut the mustard.
Not supporting all server types SUCKS, WebAssist.
Craig
Craig
No, UE 3 does not work in DWCS5.
you will need to use DW CS3, or DW 8 with UE 3
Hi Jason
I've used 3.0.7 successfully in CS4. If fact, your web site says 3.0.5 was "Updated for use with Dreamweaver CS4."
Why not update it for CS5/CS5.5 as well?
Cut your loyal customers a break.
The whole world is not PHP, after all.
