image rotate issue
Thread begun 9/30/2011 7:47 am by gruant2000381341 | Last modified 10/19/2011 9:29 am by gruant2000381341 | 3797 views | 7 replies |
gruant2000381341
image rotate issue
url removed and updated below
Image number 4 was uploaded, then rotated via powergallery2 admin area....now it is not centered and cut off
Image number 5 was rotated on my computer then uploaded (same image)...it is centered and not cut off
delete the /myGallery2/images/one/cache/myGallery2/images/one/proportion and /myGallery2/images/one/cache/myGallery2/images/one/crop folders to have the cached images regenerated.
gruant2000381341
this function is not built in to powergallery2?
how will I instruct a client on how to do this
neilo
Would applying/removing a watermark force a re-processing of the images (I don't know - just wondering?).
gruant2000381341
I just tried your watermark idea and it didn't do the trick, thanks for the try though.
I'm not sure what to do at this point, I have been putting version2 through it's paces and it is really falling flat.
gruant2000381341
jason, i just manually deleted those 2 folders like you said but the problem still remains
url removed
image 4 is still chopped off and not centered
image 5 is the way it should look
gruant2000381341
resolved
here's the fix for anyone else who's images are not rotating properly
in the webassist/caching folder.... PG_CachedResize_Image.php
open that and find this (line 46-48 on mine)
$this->width = $info[0];
$this->height = $info[1];
$this->mime = $info['mime'];
replace those lines with this
if ($this->rotate_angle == 90 || $this->rotate_angle ==270) {
$this->width = $info[1];
$this->height = $info[0];
} else {
