CAPTCHA does not show + other issues
Thread begun 9/25/2011 7:56 pm by wdlis357973 | Last modified 9/26/2011 8:02 am by Jason Byrnes | 2016 views | 1 replies |
wdlis357973
I finally got the powerstore running but still have some issues before I continue adding products.
1. the CAPTCHA does not show and one can't send an email on the contact page.
contactus.php
2. The tittle on the middle pod on home page can't be aligned, it is lower.
3. When I click on checkout, I get this warning that the website identity can't be identified
703 3609266
Thanks,
Alisa
1) the file that generates the captcha graphic:
WAVT_CaptchaSecurityImages.php
is giving a 500 server error, make sure the permissions for the WA_ValidationToolkit/ folder and all files under it are set to 755
2)
in the webassist/plugins/caltalog/featuredbox.php file, change:
<h1><?php echo WA_getCMSContent($database_PowerStoreConnection, $PowerStoreConnection, 'Featured Pod' , 'Header'); ?></h1>
<h1><?php echo str_replace(array("<p>","</p>"),"",WA_getCMSContent($database_PowerStoreConnection, $PowerStoreConnection, 'Featured Pod' , 'Header')); ?></h1>
in the webassist/plugins/popularbox.php file change:
<h1><?php echo WA_getCMSContent($database_PowerStoreConnection, $PowerStoreConnection, 'Popular Pod' , 'Header'); ?></h1>
<h1><?php echo str_replace(array("<p>","</p>"),"",WA_getCMSContent($database_PowerStoreConnection, $PowerStoreConnection, 'Popular Pod' , 'Header')); ?></h1>
and in the in the webassist/themes/bannatree/templates/index.dwt.php file, change:
<h1><?php echo WA_getCMSContent($database_PowerStoreConnection, $PowerStoreConnection, 'Middle Pod' , 'Header'); ?></h1>
<h1><?php echo str_replace(array("<p>","</p>"),"", WA_getCMSContent($database_PowerStoreConnection, $PowerStoreConnection, 'Middle Pod' , 'Header')); ?></h1>
3) the problem with the checkout is the SSL Certificate for your website. It is registered for the following domains:
*.startlogic.com , startlogic.com
you will need to contact the host to have the ssl certificate issue corrected.
