File Manager with Session Variables
Thread began 9/24/2011 7:28 pm by ddileo415479 | Last modified 9/26/2011 8:43 am by Jason Byrnes | 847 views | 1 replies |
ddileo415479
Is it possible to set the upload/file manager to a folder within the directory that is set to a username (session variable)?
images/<?php echo $_SESSION['MM_Username']; ?>
The folder would be manually created on the server, but since everyone uses the same "page" to edit content, can a session variable be used for the editor? This way multiple users only have access to the files they have uploaded.
it will require hand editing the webassist/kfm/configuration.php file.
the lines that sets the upload folder location is:
$kfm_userfiles_address = '../../images/';
$kfm_userfiles_output = 'images/';
this sets the upload location to the images folder of my site, it may be different for your site.
you can add a session to the path by changing that to:
@session_start();
$kfm_userfiles_address = '../../images/'.$_SESSION['userID'];
$kfm_userfiles_output = 'images/'.$_SESSION['userID'];
this is using a session named userID, you can change this to another session if you like.
bear in mind, that this is not a supported modification, you will need to be comfortable editing PHP to get this to work.
