Page will not load after adding recordset
Thread begun 9/21/2011 4:13 am by Jon Cunningham | Last modified 9/21/2011 10:30 am by Jason Byrnes | 4186 views | 8 replies |
Jon CunninghamBeta Tester
Hi Guys,
I have a strange mystery going on here.
If I add a record set to my page even a simple one such as :
SELECT *
FROM settings
and try to view it on my live server i get the following page error
Table 'web81-ahc200db.settings' doesn't exist
if i remove the record set the page loads fine..
The database and table both exist
Any pointers in the right direction would be appreciated.
FYI I have added the page with simple record set and db that i am using.
Kind regards
Jonathon
the SQL dump you provided seams to be from your local database.
if you are getting this error message when previewing the page on your remote live server, you need to make sure the settings table exists on the remote live MySQl Database.
If I remove the following sql statement
SELECT Vehicle.*, manufacturer.VehicleManufacturerName
FROM Vehicle INNER JOIN manufacturer ON Vehicle.VehicleManufacturerID = manufacturer.VehicleManufacturerID
"this outputs the Vehicle manufacturer Name instead of the id"
The page loads without any errors on my live server.
I have two sql statements utilising this sql statement
The one above and this one
WHERE vehicle.VehicleCotw = 1
ORDER BY vehicle.VehicletUpdateDate ASC LIMIT 1
Any help would be appreciated.
I have added both files in a zip along with a sql dump of my live server.
Jonathon
I'm sorry i dont follow at all what you are asking, can you please clarify what it is you are asking in your previous reply.
Sure no problem.
I have created two record sets using the following SQl statements on two different pages respectfully.
rsCaroftheweek
and WADAvehicle
I have no issues with the above sql statements on either pages when running on xampp.
However, when these pages are uploaded to my live server and view my pages i get the following error and the page does not load.
Table 'web81-ahc200db.settings' doesn't exist.
By removing the following sql statement code from both record sets the pages load.
I am at a loss why on my testing server xammp it work fine but not on my live server. hmm
Kind regards
Jonaathon
further:
Table 'web81-ahc200db.vehicle' doesn't exist
Sorry missed typed on previous post
this means that the tables do not exist in the live MySQL database on your remote server.
you will need to take the SQL File you sent to me, and run that SQL Script on the database on the remote MySQL Server to create the tables.
Wait you say:
is it
or is it:
I'm getting confused.
if it is:
then it could be a case sensitivity issue.
in the database dump, the table is named "vehicle" in your query you are using "Vehicle"
try changing the case:
SELECT vehicle.*......
instead of:
SELECT Vehicle.*......
Jason you never fail to amaze me.
There is a lesson I will not forget.
Worked a treat.
Thank you
So it was case sensitivity then?
Glad to hear it's working.
