Recent support fix
Thread begun 9/21/2011 3:02 am by Steve E | Last modified 9/21/2011 8:55 am by Steve E | 2345 views | 4 replies |
Steve E
Recent support fix
Hi
I am currently building a new site, I have used site sculptor to create the basic structure of the site, I received your E-mail yesterday regarding security vulnerabilities, I have downloaded the zip files and read the readme file, it mentions replacing the configuration file within webassist/kfm/configuration.php, I do have a webassist directory but no kfm directory?
Do I need to take any action on this? the version of site sculptor was purchased around March, I recall receiving an email with regard (to either site sculptor or power cms) informing me that an update addressing some ie compatibility problems, but as I had already explained to my client she may have to use firefox to upload images etc, I have not installed the update?
I do have a kfm directory within HTMLeditor this does contain the configuration file?
Please could you advise me on the best course of action.
Thanks in advance.
The initial instructions for the site sculptor fix had an error, we apologize for any inconvenience.
For each of your site sculptor sites, the updated configuration.php file should be copied to the following folder:
HTMLEditor/editor/plugins/kfm/configuration.php
to fix the issue in the extension for any new sites you create, copy the updated configuration.php to the following location under the users configuration folder (for help locating the configuration folder, see the Common Installation issues PDF:
common_installation_issues.pdf):
Shared\WebAssist\SiteSculptor\cms\files\HTMLEditor\editor\plugins\kfm\configuration.php
Steve E
Hi Jason
I did that now when trying to upload images I get the following error
Warning: require_once(../../../../webassist/framework/library.php) [function.require-once]: failed to open stream: No such file or directory in C:\xampp\htdocs\MYSITE\HTMLEditor\editor\plugins\kfm\configuration.php on line 3
Fatal error: require_once() [function.require]: Failed opening required '../../../../webassist/framework/library.php' (include_path='C:\xampp\htdocs\MYSITE\HTMLEditor\editor\plugins\kfm/includes/pear;.;C:\xampp\php\PEAR') in C:\xampp\htdocs\MYSITE\HTMLEditor\editor\plugins\kfm\configuration.php on line 3
Any Ideas? I assume this is because of the links in the file?
Steve E
Thanks Jason,
I have uploaded the updated new file and every thing seems fine again now.
