Validate Against Recorset
Thread begun 9/20/2011 9:44 am by jeff382039 | Last modified 9/20/2011 11:54 am by Jason Byrnes | 1296 views | 1 replies |
jeff382039
I want to check the values against a recordset (loop through all of the results of a given cloums) and trigger the redirect if the chosen variable and any result doesn't match.
For example :
Recordset would return:
Red
Blue
Green
And The Variable would be yellow, so it would trigger the redirect, however if the variable value was Red, everything proceed as normal.
Is this possible>?
the concept would be the same as in this thread, only the opsite:
showthread.php?t=15535
in that thread, they are trying to make sure the value is not in the database, so the numeric validation uses a minimum of -1 and a max of 0 to make sure the recordset is empty.
Use the same idea, but use a minimum of 1 and max of 100, this way validation will pass only if the value does exist in the database.
